When I'm doing a backup all of above on my fanuc robot,
Sometimes, I seen "Cannot backup files" on a lot of file.
So I cancel the backup then I see "File Not found".
Someone can tell me why?
New postHi there!
Go through below tutorial and follow each step carefully.
Hope the problem would resolve.
https://forum.diy-robotics.com/hc/en-us/articles/360035636932-Backup-on-USB-key
Back up file sometimes contains data from 20 MB to 512 MB. Make sure you have enough space in the USB.
This situation happen when the path where you trying to backup does not exist.
- Be sure that your USB key is connected correctly
- Be sure that the directory of your backup exist and have no blank or special character.
Jumping in to update the link Masako provided:
https://diy-robotics.com/tutorials/fanuc-file-management-backup-on-usb-key/
