Hi Everyone!
I am looking for suggestions. What are OEM Recommendations for Preventive Maintenance of Industrial Robots?
Hi Everyone!
New postHi Iqra!
You will find this information on the operating manual of the robot, but there are some universal rules, here is a very good collection:
https://motioncontrolsrobotics.com/how-often-do-robots-need-preventative-maintenance/
Hello Iqra ,
Hope you are doing well.
There are few standard steps you can follow.
1. You should take a backup of your robot programs at regular interval of time.
2. When the robot is in motion , check every cables , motors noise , fasteners , harness . All should be in good and acceptable condition.
3. Through inspect the brake operation. Due to repetitive use of emergency stop button effectiveness can be weakened.
4. Look for any oil spillage , abnormal noise , vibration.
5. Use recommended grease at joints and wherever it is necessary.
6. Check electrical components i.e. cables , fans , plcs , power supply boards , safety switches etc.
7. Through check teach pendent , Inspect each and every button are working in good condition.
8. Keep neat and clean the electrical compartment. Use blower to clean the dust in fans and at areas which are prone to dusting.
9. Check batteries and RAM , Change if not working on good state.
10. Check Balancer and apply grease.
11. Run robot in neat and clean environment as mentioned in the robot documentation.
12. Replace bat. in robot arm and controller when required.
Hello Iqra!
Glad to tell you that I am able to answer you with never known details. Here is the way to go step wise for preventive maintenance of Industrial Robots. I am going to explain you with specific periods to have a check and balance on your robots.
Daily Checks:
Monthly Checks:
Yearly Checks:
I hope this maintenance guide will help you have a better check and balance on your industrial robots.
Hi Losev!
There are different types of greases which can be used. Following are some best types of greases available.
I hope you are satisfied with the answer.
5 comments
