Hi guys!
I know it is very basic question but I wanted to ask. So here is my question.
What is the best type of Industrial FANUC Robot which is capable to operate in vacuum environment such as chamber and is also able to reach to about 72"?
Here are a few details.
- The arm must be anthropomorphic in order to function correctly over a movable platform having 7 axis.
- The robot must be able to operate over 10^-6 torr.
- No petroleum products be used in the robot.
- Vacuum grease must be used instead of common greases such as Krytox.
- Payload should be around 35 pounds.
- Teflon material must not be used as it grows under vacuum and is shrinking in atmosphere.
Any suggestions will be appreciated...
Thank You
