FANUC VLANs and Ethernet I/P Communication
Hi all !!
I am having a big FANUC system having different ETHERNET devices. It has a main dell connector for Power and 7024 ETHERNET switch and I am using for managing it for ETHERNET traffic. However, in DELL switch I have set up VLAN for cutting down on the ETHERNET traffic for its ETHERNET card and I am also having Control Logix PLC. There are a total 3 of it.
Now I am having LR mates on the same FANUC system having controller R30iA version 7.7. I am having trouble with its controller. My PLC is on VLAN 3 with an IP address of 172.16.3.2 for example, my robot is 172.16.4.3 (subnets are set at 255.255.0.0).
I am having safety CIP connection and it is working fine but the normal ETHERNET I/P connection is going IN and OUT. However, about 1 second of better response, it has no connection for next 7 to 10 seconds and then connection re-establishes. I know my PLC is configured correctly since when the switch is at factory settings it works just fine.
I am curious if anything is in the I/P connection of FANUC that is not allowing the VLANs and I/Ps to work?
I am having a similar setup before and it worked fine, but I didn't have ETHERNET safety.
Any suggestions will help.
  • 1
