Hi all!
The gap in the part is irregular, i want to change welding speed according to the gap which will be detected by sensor during arc welding, but how can i change weld speed dynamically by program?
Help! help!
Hi all!
Help! help!
New postHey!
Try this code if you are using KAREL.
$GROUP[1].$speed = speedvar
Try this code is you are using TPP
OVERRIDE=R[200:SPEED]
