I recently bought my FANUC S10 and is having problem with startup. When i am turning ON its control panel over the teach pendant, then it shows some of errors when it is trying to load MAIN1027. The error which appears is "Error 109" and is in CM0 module. The error parity is "Error 45".
The controller gets non-bootable and it gets freeze and i am not able to move anything.
I have already checked the status of LEDs inside the control panel and all seems good. The motors are not energized and the LEDS over the front panel are also OFF.
Someone please tell me what problem this could be?
