Hi Everyone!
I have Fanuc SIT Touch Sensing (RTL-J536-AT Fanuc Seam Tracking Welding (RTL-TAST-AT) Constant Path Software (RTL-R663) RJ3iC Controller (165 kg CAP 2655mm Lincoln Power Wave 455M(Welder) Lincoln Wire Feeder.
Problem that i am facing is with parts to be welded. Parts need hard-facing but many that come back need build up with weld and machined back down, then go back on robot for hard-facing. it would take too long to teach each part to the robot. Can you suggest a software out there that can 3d scan an object, put into program to outline points of welding?
I would really appreciate any guidance!
