The variations of actual and roboguide
Hi all,
I am having an issue that while working on the hemming application through FANUC 210F Robot. While simulation was in progress in the RoboGuide software doing the corner hemming I am using the 150mm per second speed and it is resulting with fine outcome. However, when i am onsite, the robot is getting vibrations  while with same speed of 150 mm per second. For its avoidance, i have reduced the speed and by doing so the impact over my cycle time is happening. Now I am in search of a way to reduce the vibrations but using same 150 mm per second. Do i need to change any parameter or what i need to do?
6 comments
  • 1
