Hi,
I am working on an application that a point cloud scanner is attached to the end of an old FANUC M16i with a RJ3 controller. For the generation of point cloud in a right way for the TCP speed and send it to the scanner so that it can space out the profiles properly, but other than grabbing the TCP position, I can't seem to find the speed anywhere.
Moreover, there is another way for monitoring the encoder values on the joints? If I have that, I can' do a quick forward displacement analysis to find the TCP position and velocity.
Thank you
