Hi folks,
I am curious whether any of you have ever used the 210 Water Environment robots for the higher pressurized washers? I have used such and now need some suggestions if any of you might help me with it.
I have been working on various of the 210WE robots deprived of having any of the protective boots in the washer chambers. I have been using approved detergents only such as (SP735) under 55 degrees Celsius of temperature with no high pressure spray over the surface of robot . I think that everything has been followed as prescribed by FANUC requirements, but still i am suffering with having a yellow paint over the arm of my robot. However, I am lucky enough to have no other issues with it.
This is because the feedback of FANUC which we got after contacting them in respect to get any preservative temperature range of controlling inside the chamber. If anyone of you are having an idea why the paint of robot is peeling off then please guide me with respective measures to be taken,
Thank You all so much for reading my post
5 comments
