Finding the Hole's center through Touch Sense
Hello All,
I am curious whether anyone of you have a specific routine to find any hole's center through use of TOUCH SENSING? I am on a project to weld different parts which have numerous holes. Each part is having about 108 holes. Along with warpage etc. in every part it is very difficult for me to hit each location on perfect basis. Therefore I am required about 0.5 mm wall thickness of the tubes to be used for welding as it is 1mm only.
I was wondering whether there is any way of using the TOUCH SENSING for the purpose of checking if there is any coupling with the center's welding at different locations all through the parts. Is there any kind of chance for setting up an incremental touch routine  that would be utilized on random basis and center of each hole would be found at each and every location?
Looking for help. Thank You
