Answered Couple of Questions related to Payload
Hi experts.
I am working on my FANUC 1000iA/100F having an R30iA controller.
I am making use of a vacuum gripper for gripping numerous different shaped and sized parts. I am interested to know of the way to setup schedule for its payload.
I assume that there are about 10 schedules for payload but I have to choose one which is closed to 100 parts.
Will I be able to do something such that whenever, I am releasing the vacuum and setting payload to 1 (0 KG) and then when i am setting the grip vacuum to payload 2. After that each and every program is set to a register for a specific part per weight.
My second question is about the model of robot. I am interested in picking up a a blank flat parts which are stacked over a pallet. Sometimes,such blank flat sheets are sticking together and the robot is picking couple of sheets through vacuum gripper.
Is there any option in payload which may enable me to check if the payload is 2 times higher or normal?
Does the robot know if it is holding like 1 or 2 or more sheets?
Please help, I will be thankful.
6 comments
