I have programming files which i tried to feed into the controller , but there is less memory and it can not support more files. So Is there any way i can transfer files from FTP and run simultaneously ?
New postThank you for your answer .
But i am aware about this. If i properly put my question , It is like the program size is bigger than the size of memory. So i just can not load it. Is there any way to do it. Currently i am parting the program , But it is very hectic task. As first program completes , I need to do login via FTP then delete the existing program. Then transfer the other program. There are chances that i may mismatch the program numbers. So i am looking for a better way to perform this action.
You can do something like , When you transfer your first program , At end of it just call the next program, Meanwhile overwrite the existing program and run the cycle via FTP.
