Hello Everyone ,
I have programmed MACRO including I/O configuration. Which is executing configuration from DI and DO. My program was running good before but suddenly this error is popping up. What can be the reason ?
Hello Everyone ,
New postThe meaning of this error is that it was aborted while execution. If you have not done anything i.e. editing in programs or changed I/O configuration, There is strong chances that there is a fault with the wirings or connectors.
You can start troubleshooting with wiring connection at I/O ports and racks as well as connectors and pins. Check the cable shielding as well. I hope it will sort out the issue.
