Hey All ,
I would like to have a mechanical maintenance performed on our spot-tool R2000ib with R30iB controller. How can i verify Gun-impedance value before and after maintenance is carried out ?
Hey All ,
New postPay close attention to the Gun Impedance Value before and after Auto Tuning. If the Gun Impedance Value increased significantly, the Servo Gun may have a bind or the Servo Motor may need to be replaced.
Always check gun impedance before and after when any mechanical maintenance is performed on the servo gun to see how it affected the characteristics of the gun.
Here is the procedure to check the Gun Impedance
1. Menu
2. Setup
3. Type[F1]
4. Select Servo gun
5. General Setup
6. Overtorque Protection
7. Press OK
8. Parameter Summary
9. Verify item 1 (Display Units) is in TorqCt if not Select F4 to change
10. Gun Impedance is displayed in the row stating “Std. Over torque Value”.
