How can i add Fence in roboguide software ? Do i need to add it externally ?
i.e. iges File ?
Thank you
i.e. iges File ?
Thank you
New postYou can add fences by two method. If you have standard fence which you have created in CAD software , You can directly import .iges file. and set accordingly or if you want to manually add fence for simulation purpose , Follow below method. There is also standard files available in Cad library. You can use that as well.
1>>
2>>
3>>
4>>
