Hello ,
Is there anyway , If i change the Jog Speed with Shift button + %+ / %- on teach pendant , It will increment the value by only 5 ? As sometimes i tend to forget not to press the shift key by usual habit.
Hello ,
New postHello ,
When you press only %+ or %- button speed decrements will be changed by value of 5 , Now when you press shift and %+ or %- button the value will increment by 25-50 . You can change this value by changing the system variable.
You can go to :-
Menu ---> Next ---> System --> Variables --> $SHFTOV_ENB --> Set Value --> 0
Now when you Shift Press or not , The action of %+ and %- , it will act same as normal operation.
