Good Morning to All ,
I have purchased Soft Float ( J6112 ). How to install this PAC to teach pendant ? Do i need to connect to internet then install and approve ?
Looking for help..!
Looking for help..!
New postHi Vicky ,
Here is the procedure ,
1. Purchase the PAC (Product Authorization Code).
2. You need to place your image file which you have received with the robot. ( It can be a install card or USB stick ). Place that in MC or UD port.
(if you do not have image file contact Fanuc , They will charge approx. $500 for image file )
3. Do a controlled start.
Here is the link for controlled start procedure :-
https://forum.diy-robotics.com/hc/en-us/community/posts/360055356211-Controlled-start
4. After performing a controlled start , Follow Below Procedure
Menu --> S/W Install --> Load Media --> Select Media --> Choose PAC option --> Authorize --> Four Digit Code --> Done.
It will take time for installation.
5. Cold Start
