Hi ,
I have made some changes in the existing ladder file and save as revision file. I copied and pasted it on the USB Stick and tried to load on the robot. But file is unsupported. Can anyone help me with this issue ?
Hi ,
New postFollow Below Procedure.
1. Make changes to your ladder program.
2. Compile your program , Make sure there are no errors present. If any error , Clear all
3. Save as the file. ( In case of Back up )
4. Go to file -- > Export
5. Select Memory Card format
6. Copy your file to memory card
7. Plug in the memory card to robot
8. Load the file to robot
