I have feeding issue with lincoln welding powerwave 455. I do not see the wire is moving when feed button is pressed on teach pendant ! Please guide me through this .!
Wire Feeding Issue Lincoln
Check if your wire can be pulled easily from every parts where wire is routed of the wire feeding system.
Feeder conduit , From Barrel , From the guides when rollers are not engaged , From Tip nozzle , From Liners
Mostly the problem is due to worn-out or rusted parts in the Feeder System.
Also check if right guides are installed and wire is used according to the guide rollers.
Good luck.
