Servo and wood
I want to fix a L shaped structure on a mini servo I don't have an 3D printer I am planning to use a small wooden skewer to make it but I am not able to mount it properly can anyone give me some ideas to mount it to the servo or some other things I can use to make the L shaped structure.
Hello Alansan,
It’s difficult to give a clear answer without a bit more context about your application. That said, and I might be mistaken, I don’t think using wooden skewers is ideal for holding your servomotor in place.
Even without a 3D printer, you still have several other options. First, it might be worth checking online to see if a bracket specifically designed for your servo model already exists. Otherwise, you could use a steel, aluminum, or even wooden L-shaped profile, like an angle bracket, for example. These are available in various sizes, and you don’t need a 3D printer to build your mount
Would an approach like this work for your setup?
Let me know !
