Why do i keep seeing this? Is it something to do with the rotation of my tooling during operation? How to adjust this variable or is there another issue?
MOTN-330 MROT Limit Warn (G:1, A:5).....
Hi Daniel,
It's because the point you try to reach is very close to the axis 5 limit. Can you go on the point and show us the joint value?
Unfortunately I have not been able to narrow down which position it actually is. The robot picks and palletizes varying size boxes. Im assuming on a certain product, the way the pattern is designed on certain pick is causing it. I will need to sit and observe to see which product and pick this is happening on.
