I have the Euromap 73 on my DIY robotic cell and I can't open my injection molding press with the back door open. Do I need the option also on my press?
New postHello ,
From the safety point of view, the external replaces the doors of the injection moulding machine. Usually the machine may only move,when the doors are closed. So the machine needs to know, that there is an external safety device. That means, the machine must also support this option. You also can not just mute the safety function on the machine, because it still has to stop , when the external safety device is open.
John68, we recommend that our customers order presses with the Euromap67 and Euromap73 option. See this link for Euromap Documentation.
https://www.euromap.org/files/EUROMAP_73_1.1.pdf?download=1
http://www.euromap.org/en/technical-issues/list-plug-suppliers/
http://www.euromap.org/en/technical-issues/technical-recommendations/
