Hi Guys,
I wanted to ask you guys, if the HMI Device R553 OPTION is standard on the Fanuc R-30iA controller or it could be initiated or selected some way?
Thanks in advance!
Hi Guys,
Thanks in advance!
New postHello Masako!
Unfortunately R533 HMI Device option is not free. This is the SPNX HMI Device option that you will need to buy , then you'll get a PAC code from FANUC. And then you install it quite easily following simple steps in few moments.
