Hello ,
I have prepared .nc file in Fusion 360. Is it possible send the milling file directly to the Fanuc Controller ? How ?
Thank you.
Hello ,
Thank you.
New postHi Braylen,
You can convert in to G-code and send it to your Fanuc controller. If the controller has a serial port, then all you need to do is configure the serial port and then do a VISA Write to send the codes and a VISA Read to get them back. In both cases, you'll need to know the command to send to the controller to prepare it for a new program or which program to read. The controller should have some documentation that explains this.
I am attaching link that might help you.
https://www.youtube.com/watch?v=Qt-1ap3du6Q
