Hello Everyone ,
Can anyone help me with the program logic.
I am planning to find the center of the square plate using the probe and pick it up with gripper
As the square plate can be at different location within the tolerance zone. I am planing to move the probe starting from the arrows and when it reaches exterior of the plate , Due to material density variation , probe will detect it and the position will be store in position register. Similarly for four other points.
So now based on the mathematical calculation , x and y location difference i can get the center point. Now i will make another position register , it will be a center position which is previously calculated instead of edges. This plate will be picked using the gripper.
In a scenario , If the plate edges are not in parallel with the work table. What can be the logic to rotate the gripper in particular angle. ?
