Hi There!
Is there a way to prioritize what is displayed in the alarm history. Like, when I get a call, I pull up the alarm history and the alarm history will be flooded with resets and alarms. Can I set priority in error codes??
New postHi Dear!
You can use Error Severity Table (Under Menu -> Setup). Here, you can choose any error code, then you can change its severity (upward only) and you can change what is done with the error code. All the details are in the Handling Tool Manual in Section 5.10, with the facility codes details in Section A.2.2 (Error Codes and Recovery).
