Hey Guys!
What are laser seam tracking system options available for FANUC robot?
Hey Guys!
New postHello There!
I would like you answer your query. There are several system options available, servorobot, meta, scansonic of sensor and intelligent laser. Probably best available option is Servo-Robot.
Dear Murillo,
The seam tracking is often known as Joint Tracking is comprising of the real-time tracking ahead of place where welding is to be deposited and is allowing the robot to shift its trajectories, however, its adaptive control like the wire feed, traveling speed, and voltage etc are to be altered through weld bead formation.
i believe you are able to understand the concept now
