Hi folks, I am getting an error of the INTP205 on my FANUC controller due to which my FANUC is not able to move to its teach, Help and suggestions will be appreciated.
INTP205 error
New post-
Comment actions
Hi Muhammad,
INTP-205 is an analog port access error. If you are not using anolog I/O then simply GO TO MENU, I/O and disable the analog I/O.
Comment actions
Dear Ishaq, are you getting any other alarms as well? check history? moreover if you are not using the analog I/O then disable it from menu.
