Hello folks,
I am in need to do the safety wiring of the output signal having a pulse check enabled with a safety relay.
I am not able to figure out that how will i wire the output for activating the relay? I have also tried the 4 Dual Channel, 1 no from the +24V and 1 No from the 0V which is CAT4PLE but the relay is already sending me 24V over the S13.
Can someone explain me how the wiring of the relay is made with SFDO? For your information, I am using the external power supply along with relay. Now please guide me whether or not to use the 24V and 0V for the safety output instead?
I will be obliged for the help.
5 comments
