Hi All
I have fanuc robot M-420IA , With R30iB controller. Basically I am using it for the Spot welding. So as 12 cycles completes, I need to clean the tip but every time it requires to touch up the points minor . It there any setting , I can use for look for. I just want some setting like , I can hold the program after 12 cycles and adjust the tip clean and it automatically adjust the touch up.
