I want to set up something like when i press cycle start button on control panel .24V realy gets activated and there is motor connected to the relay. So it will turn on.
How can i do such setup ?
Thanks
Thanks
New postHi Losev,
When you are having infor of the "Control Everything" boards, then you may opt for either "Higher Power Relay Board" or "Lower Power Relay Board" or "SSR7 Board" for the control of a power ratings of different values.
Whereas you may have the "FET Relays" which is a cheaper option for acquiring control.
Good luck
You can even control with DO output on AOD16D and connecting it with relay. Use background logic in your program to start the motor.
