Hi guys,
Can anybody tell me what is the procedure to test for purge air leakage?
Hi guys,
New postHi Ernesto,
Testing your robot for Purge leaks include following:
2. Also You should pay close attention to:
Have a Good day!
Thanks sarwat. :)
Wanted to ask one more thing, which Hardware do i need to perform purge cycle testing?
You will need following equipment to perform the remedy procedure.
1. Air compressor / any air supplying source which is capable for supplying air approx 1000-1200 lpm.
2. Pressure gauge
3. 2 Nos. Air fitting , 1/8 or 1/4 NPT
4. Nylon tubing measuring 1/4 dia. , 24 inch length
5. Leakage detect liquid
Dear Ernesto,
Here is the necessary Hardware to perform purge cycle test:
Hi Ernesto,
There are various methods through which you can check Air Leakage. Some of the widely adopted methods are as follows.
1.Bubble Test/Submersion Test.
2. Ultrasonic Measurement
3. Pressure Decay Testing
4. Vacuum Decay Testing
5. Helium Sniff Testing
6. Helium Spray Testing
7. Helium Accumulation Testing
8. Nitrogen Purge Testing
9. Hard Vacuum Testing
Best of luck!
7 comments
