Hi everyone,
I am using FANUC robot and trying to get an accurate TCP through 3 points method and 6 points method as well. I have even tried modifying the direct entry measurements. I have a welding torch over the robot & able to get it reasonably to about 3 mm rotating its face plate over the axis 4 and 5.
However, if its wrist is approximately 5mm out while flipping its wrist back to about 3mm then how accurate I am able to get this welding?
The robot is going to travel in a very straight line.
Does any of you have an idea whether it will make it to move in circle with lesser accuracy?
I have done the re-mastering to about ZERO degrees however, seen no improvements. I am having original measurements for the comparison but these are not corresponding to the one used in robot at the moment. Every thing seems to be running fine but would be easier to jog around parts with a more accurate TCP.
Please help. Thank You
6 comments
