Hey ,
We have 6 production robot and one of the robot show SRVO-171 Motor speed limit /DVC (G1 : A4). We have checked every cable controller panel fuses everything. But in vain. Can anyone help us in this situation.
Hey ,
New postHi Toby cooke
It is merely a warning you should ignore it. And if you have found it harmful you should increase its severity so that it stops your robot.
SRVO-171 WARN MotorSpd lim/DVC(G:%d A:%d)
Cause: Motor can not rotate as fast as the calculated speed required for the current motion.
Remedy: This is just a notification. You do not have to do anything for this warning message.
Thanks for the answer. We had a lot of work pressure.We have skipped maintenance since last two times. Can it be the issue ?
There! you are getting this all because of delayed maintenance and you should take care of the maintenance. It could possibly cause any other alarms in the near future
Yeah , We have changed the grease . It was all dark in color since then alarm is not showing up. Thanks
