Hello all,
I am going to ask a question. It may sound silly but i need an answer.
How will i be able to change the process of welding? Is there any way or not? I am working on 100iC controller.
Thank You
Hello all,
Thank You
New postFollow this video , You can change welding parameters. I hope it will be helpful.
https://youtu.be/NpJz1JObpN4?t=347
Hey Jordi,
Are you able to access the variable that you are desiring in the welding register?
Here is the way to access.
<Data>
<Weld Schedule>
<Detail>
Regards
You might have a requirement of the multi-process to be enabled.
It's been a very long time since I did this. However, I think that it can be done through CRTL start set $AWSCFG.$MULTI_PROCESS=TRUE.
Good luck
