Hey All ,
I am receiving this alarm as soon as i turn on AUTO mode. I have checked the fence. Is it closed properly. Any other connection i should look for ?
Thank you .!!
Hey All ,
Thank you .!!
New postIf you have done the fencing wiring with hard wire method.
- Check all the wire connection.
- Check the shielding of wires if there are any cuts.
- Check safety relays / contactors
If you are using PLC for fence circuit , check I/O connection and status of all connection whether they are working fine or not.
