I have gotten all the parts in for this and soldered together the board. I loaded up the arduino micro with the software. I then plugged in all 6 axis servo motors for a test to make sure everything was behaving as it should. I plugged in the external power supply and turned on the power switch. All servos seemed to center themselves just fine. I opened the included software to try jogging the joints around to make sure that everything was okay. The software detects the board and will connect to the board. However, all of the axis read 0 on the left panel. When I click on J+ for any axis on the right panel the servo will rotate just fine. However, when I release the J+ button the servo simply returns to 0. J- has no effect at all. While jogging the axis position monitor on the left side does not show any movement.
I have tried:
- Reloading the arduino software
- Checking all solder connections
- Turning it off and back on both while connected in the control software and while not connected.
- Unplugging the servos and plugging them back in.
- Only 1 servo plugged in.
All of this has the same result as above.
What did I do wrong? Has anyone else had this issue?
38 comments
