Can anyone recommend alternatives to the transistors in the BOM for the robotic arm DIY. TRANS NPN 40V 0.2A TO-92 (P/N 2N3904BU). They're out of stock from digi-key with no restock date (the great 2020/2021 silicon scandal).
Educative Cell V1.0 - Bill Of Materials (BOM) - Alternative Transistors
Hi Anthony,
You need a NPN bipolar transistor with TO-92-3 package.
This one would fit just fine:
Digi-Key Part Number LP395Z/LFT1 -
Also, note that there is an error in the BOM for R1, R2, R3 resistor value.
The adequate resistor is 270ohm, but the BOM links to a 270 k ohm resistor.I suggest the following component:
Digi-Key Part NumberRC14JB270R-ND -
