Do you have a procedure for the mastering of a CRX? I'm having trouble of finding it in the new tablet teach.
New postHi Sylvain,
To begin on the TP tablet you need to open the drop down menu list, then press on this button to get the full menu list
Then in the menu go to SYSTEM
If you don't see MASTER/CAL in the list you will need to go and enable Master/Cal in the system variables to make it enable.
From here I suggest you to follow the DIY tutorial with this link below to help you out with the Mastering and configurations.
https://diy-robotics.com/blog/fanuc-mastering-procedure-quick-mastering-procedure/
Hope this will help you out!
Good luck!
DIY-Robotics products
https://diy-robotics.com/products/
