Hi all. I just received a new Cert Cart with the ER-4iA unit on it. It has a laser scanner underneath to interrupt and stop the robot if a student approaches it while in AUTO mode running a program. I have run into an issue whereas the demo programs from the factory run as they should and the robot stops if someone gets too close, but any new programs I create, fail to activate the safety zone. So any programs I create, continue to run at programmed speed, even if someone comes right up to the unit. This is a huge safety issue in a high school lab, and I need to figure it out ASAP. Any one have any ideas?
