Incorrect robot movement after battery replacement
Hello, the voltage on the batteries was lost and they were replaced, after that mastering and calibration was done, the TCP was set up, but after all this the robot moves uncorrectly, that is, I choose the WORLD coordinate system (or any other except JOINT) and when I start moving the robot along the X coordinate, the robot instead of straight-line movement, it moves diagonally, along the Y coordinate instead of the linear one, moves in an arc, along other coordinates +- the same thing, maybe who knows what the problem may be. Maybe I did incorrect mastering or setup of the TCP. Robot Model: FANUC ARC MATE 120IBE
7 comments
