What is remedy for this error ?
Thanks
Thanks
New postChadwick, you communicated with which PLC. Rockwell, Omron, Mitshubishi, GE, Koyo ?
Do you have more information ?
In the EDOC Fanuc CD, there is a section on error codes.
Hi There!
PRIO-035 WARN PLC interface serial fault
Reason: The serial link to the PLC has failed.
Remedy: Check LED status on PLC interface board. Refer to the FANUC Robotics manual, A User's Guide to the FANUC Robotics SYSTEM R-J3 Controller Remote I/O interface for an Allen-Bradley PLC or A User's Guide to the FANUC Robotics Genius Network Interface for GE FANUC
