I have M20iD/25 robot connected with fence and External E-stop button. Due to some reason, The external E-stop switch is broken. Now i am not able to move the robot, As the signal stays always ON. I have ordered the new switch , It is on en-route , meanwhile how can i bypass this signal ? Do i need to make any electrical connection between them or any other suggestion ?
Answered External E-stop always pressed
If you have set up the connection in User Input signals.
Go To Menu --> System --> Config --> Enable UI Signals --> False
After setting it up , You can reset and move your robot.
if it is hardwired , then you need to disconnect the wire and change the switch.
Thanks ,
It worked. Now robot is not asking for any external E-stop signals. I read it in manual as well.
