CRX not moving when Enable UI Signals is TRUE
I want to start the robot with an external button linked to a UI signal. When I put the Enable UI Signals at TRUE in SYSTEM- CONFIG, the robot is not moving event in teach mode. How can I start the CRX with UI signals?
