I have a ARC-Mate 120i 224ish years old. My J5 has this error. No crashes that I'm aware of around the time this error starting showing. I can't clear it by the teach pendant. I have to cycle power at the controller. Probably need to call someone was just hoping that their might be something obvious to look at. cant see the motor or cable there are inside J3 Arm I believe. Any i can look at on the TP thight might tell me if someone changed variables? this fault when I move J5 both + and - roughly 25 degree from 0.
